Hello.
Just did a small service call.
The bed room circ where the flat screen tv is plugged in is probably on the same circ as bath hall and other bed. Didn't look that deep. I put a receptacle tester in the power strip supplying the tv. The tester and cable box stays lit/on Occasionally when turning on a light in the bath hall or bed the tv will go out and back on. not shut off to have to turn it back on but will go out then back on. Like cycle.
Anyone see this before ?
Thank you
Thank you
