Brian9
- Mansfield, Ohio USA
Greetings --- I am an electrical engineer at an OEM tasked with retrofitting a submersible pump control panel. The new control panel needs a moisture/thermal relay wired in, however, there is no room physically for the relay in the original panel. I will need to provide a new 10x8 panel to house the relay and then have the customer run conduit between the panels. The 10x8 will be mounted close to the original panel, well within reach (power cable from the pump will go to the original panel, moisture/thermal sensing cable will go to the 10x8 panel --- both cables from the same pump, so panels will almost have to be mounted close to each other).
Really trying to keep the cost down for production of this new panel so I really don't want to have to include a 120VAC power on/off switch on the door. Is there anywhere in the NEC --- like an obscure execption or something --- that gives me an out from having to provide the on/off switch on the 10x8 panel? It is very close to the supplying panel. Could I put a label on it or something?
Thanks, Brian9
Thanks, Brian9
