There is equipment that uses open a nichrome wire heating heating elements. I am being told by an NRTL that the wire on the heater failing is a "normal part of the heater life cycle" and that I should use GFCI breakers.
I've never really used GFCI's on anything other than outlets. I am not able to replace the entire branch circuit over current protective breaker with a GFCI am I?
The equipment can be considered as a branch circuit, but I am looking at the branches inside the equipment as individual branch circuits. One of which is the heater circuit. Will I need to use 1 normal breaker and 1 GFCI breaker? Can I size my wire of a GFCI alone?
