800-amp main connted to 12 meter stack automatic transfer to connect to only 7 meters
The seven meters to connect to a automatic transfer switch are one 400-amp 3ph 4w 208
four 200-amp 3ph 4w 208 and two 100-amp 1ph 3w 208. sizing the generator is not a issue.
The issue is the automatic transfer switch is it possible to have one built to accommodate all
seven units at once.
Johnny's
If I read you thread title correctly, there is an 800 amp main ahead of the meters. Is that correct ?
If so, is it a part of a meter-combo assembly or a separate unit ?
It sounds to me like you will need seven transfer switches of various capacity.
Keep in mind the transfer switches must be on the load side of the meters or they will be paying the power company to use the generator.
glad you caught that.... I was heading down a bad road :D (not the 1st)
