Adams14
- Commerce City, CO
I work in public buildings that are older where the conduit is used as fault path. There was a flood in a lunch room some 115 volt floor outlets were totally submerged and the circuit breakers did not trip, the water was boiling hot. After investigation the subpanel had no EGC and one locknut. the branch circuit from that subpanel had no EGC. I find this kind of installation all of the older buildings district. Is there a testing method measure ground paths, or a tester that cam measure ground paths. I don't feel comfortable with the direct ground test (touching energized conductor to a J-box or conduit).
