xguard
- Baton Rouge, LA
I've found circuit breaker catalogs and websites state this or something similar:
"The NEC (or UL in one case) allows the breaker to be rated at 100% of its frame size in an assembly, provided that 90 degree C wire is applied at 75 degree C ampacity."
Does this mean 90 deg C wire must be used?
Or can you can still use 75 deg C wire at it's 75 deg C rating?
