SolarAlternativesDesign
- Soulsbyville, California, USA
For a PV combiner box, does NEC 690.16(B) permit use of a fused combiner box with touch-safe fuse holders, or is a switch type disconnect required? 690.16(B) requires a sufficient interrupting rating (referring to 690.17), but states that "Non-load-break-rated disconnecting means shall be marked "Do not open under load." Does a touch-safe fuse meet the definition of sufficient interrupting rating? What are the definitions of interrupting rating and load-break rating?
