Can anyone provide me with the technical specfications for 16 Gauge Black Annealed Steel Roll Off Tie Wire?
Is it listed as a means of support for 2x2 and 2x4 luminarie support?
As far as the NEC goes it's a non issue, local building codes are what matters in this case.Can anyone provide me with the technical specfications for 16 Gauge Black Annealed Steel Roll Off Tie Wire?
Some are listed AFAIK. Most applications of use don't require them to be listed though.Iv'e seen it used to secure fixtures in wood frame buildings. The wood joist were no more than 18" above the drop ceiling if that matters. For ceilings in other uses grid support wires were always specified. That is separate wires for fixtures & separate wires for ceiling grid.
Are Zip ties also known as Ty Wraps listed ? They get used frequently for support of MC cable, thermostat wire.
