bobby ocampo
Other than the National Electrical Code? What other standards will show the definition of 230 volts, single phase, 3wire? Any reference standard?
Try 141, the red book. If you want a better description with how it is metered, use the EEI Handbook for Electricity MeteringI am looking for IEEE reference standard that will show the meaning of 230 volts, single phase, 3wire
I didn't know there was a meaning to 230V single phase, 3 wire. What exactly are you looking for....I am looking for IEEE reference standard that will show the meaning of 230 volts, single phase, 3wire
ANSI Standard C84.1L Electric Power Systems and Equipment ? Voltage Ranges defines standard electrical equipment voltage ratings and tolerance limits for steady-state ac electrical systems from 100 V to 1200 kV. The nominal system single-phase voltages under 600 V are 120, 208, 240, 277, and 480 V. For each nominal system voltage, there are two voltage ranges, Range A, or the ideal voltage tolerances, and Range B, which includes Range A but goes beyond the limits of Range A on both the high and low ends.
Within each range are service and utilization voltages. The service voltage specifies tolerances for delivered voltage to the service entrance; the utilization voltage limits specify voltage tolerances for electrical equipment.
Perhaps consider IEEE 100Other than the National Electrical Code? What other standards will show the definition of 230 volts, single phase, 3wire? Any reference standard?
It seems like such a simple request doesn't it? I have seen this asked on multiple occasions for more than one question but very little clarification is given. Kind of makes it hard to help when the OP won't explain.I didn't know there was a meaning to 230V single phase, 3 wire. What exactly are you looking for....
Thanks Sir. what does EEI means?
Yes.To Me it means "Edison Electrical Institute" Google it for more information
