NjWireMan
- New Jersey
I got called by a customer to come out and fix their pool Wiring for the Filter and add a Timer. Here is what I found.
1. Uf cable sticking out of the ground and the end is in a Blue Receptacle Box. (they removed a shed that housed the the filter and outlet)
2. No equipotential bonding to be found.
So I am not really sure how to go about this. Here is what I know. 680.21A1 says uf cable is no good because the ground is not insulated. However 680.21A4 says a uninsulated ground is okay in a Cable Assembly. Is Uf cable considered a Cable Assembly? We are still using the 2011 Code.
How would you guys handle this scenario?
