LED driver correction
electricalist
dallas tx
On another thread I had stated the lithonia rep told our inside sales guy that with LED drivers the amperage does not change. He is wrong. We hooked up all 42 lights on 1 277v circuit.
Sorry I left out that he told us it didn't matter what voltage is used on a LED driver the amperage is the same . we thought we would need more circuits than the plans called for. Today we hooked up all 42 2x4 lights to one 277 v circuit.
When I get home my son is climbing on me ans trying to take my phone and my post end up more confusing. Aorry
Enjoy the climbing while you can. I can hardly get my 9-year old to give me a hug sometimes. 'Cause, you know, he's a big boy now.
so these are universal voltage drivers?
one single hot wire, not different ones for different voltages?
True
The actual amperage makes no sense.
When we hooked this one driver to 120v it pulled .35 amps that x 2 drivers per light is .7 so as mentioned the label on the fixture is in correct.
At best we figured we need 2 circuits but today we hooked them up to 277 and they all held.
Its my responsibility if I'm gonna do this type of work to learn and know the products.
With poor labelling, mis informed reps and constant hurry up schedule.
The highlight of my day is my son waking me up at 3 am. Daddy, Daddy, Daddy.....what! ,,he says,,,I needja help. Unlock door I wanna go play.
It's not a surprise that real measurements read about 120 over 277th times the amperage. :)
Although, it may not matter for nominal/list amp ratings. :shrugs:
I agree it doesn't make sense and someone must have goofed something up on the label. I haven't seen any of the LEDs that I use labelled with an ampere rating, rather they just give the watts. That number can't be used for sizing dimmers since evidently you have to multiply it by a factor of 10 or so or the dimmer will malfunction when turning on the load.
I think that a correct statement is that regardless of the supply voltage the current through the LEDs does not change.
With a buck circuit in the driver that does not imply the supply current staying the same.
Not everything have the same nominal to real compliance.
A space heater may have real and actual amp that are very close together. A window AC may call for a dedicated 20A 120v circuit, because the nominal continuous amps are 12.5A if you were to use it in Death Valley. but measured amps may suggest 15A circuit is adequate even after the 25% allowance. This does not mean that you have the discretion to cut the plug off and wire it up for 15A circuit. These are things determined by specifying and factory engineers.
