I agree.I would expect in many cases, that is a direct reflection on the quality of the construction documents and not on the quality of the worker.
So you have got a group of guys who have worked out all the kinks; figured out what you mean instead of what you say and have not offended you in the process. Fair enough....it's roughly 70% getting it to start, then 30% implementation (in my experiences). This is also why we try to keep the same contractors doing work for us "sole source".....
There must be a way to contact the manufacturer of the skid/building. I would think they would have more relevant information as opposed to the customer.
That's a pretty brave assumption, but :happysad: nope...I would expect in many cases, that is a direct reflection on the quality of the construction documents and not on the quality of the worker.
In the last five years I have encountered no less than three Master Electricians who did not understand that the use of isolated ground receptacles did not preclude the proper grounding and bonding of the electrical system. They wanted to use truly isolated ground rods....as in not bonded. One master didn't even run a ground to the panel before he applied his sticker.
These were Master Electricians from North Carolina, Washington (owned his own business), and California.
The drawings were very clear on the proper use of single-point grounds...and in accordance with the NEC.
Don I think that you have said it all. I have had AHJs as diverse as the Corps of Engineers and the owner of a totally unregulated embassy's building manager. I have done Electrical Equipment Shelter installs from Tierra del Fuego to Alaska and Myanmar to Uganda and the difference in the quality of the installation documentation is boggling. Even when I was only functioning as the manufacturers liaison on the install I had to spend a lot of time getting the various actors to follow the same stage directions. How was I to know that neutral conductors in South America were generally blue in color. One week I'm on the factory floor bending a hundred repetitions of each piece of conduit for an order of shelters and the next week I was in Buenos Aires trying to explain why I wanted four conductors in the single phase feeder to our shelter which is to be assembled under an existing radio tower in an existing telephone company complex but that I don't need four conductors to the utility transformer on a brand new site. The only ones that were easy to get installed were the totally self sufficient units that were assembled on remote ridge lines with their own hybrid power production as part of the install. It took me a long time to understand that the reason that Telefonica Argentina wanted Steel used in the construction of shelters that had to be sited using Helicopter hours was that the steel walls had a better chance of withstanding the plinking from the 30/30 carbines of the bored Gauchos on the pampas below. It probably didn't help that the only Spanish phrase that I new was "donde esta el ba?o"Well then you get much better drawings and specs than we doI haven't seen what I would call a quality set of drawings in about 20 years.
Probably a good reason for that. If you spent 1/4 of the words to educate that you have instead spent bragging and talking down to OP, he would already be much better informed.I get the condescending attitude a lot from people...
