Ohms law
- Sioux Falls,SD
Do I need to bonding jumper for a metallic raceway into a disconnect that enters into a concentric knockout, even if I run a equipment grounding conductor with the branch circuit.
I understand bonding at services and bonding for over 250volts but I am somewhat confused if this is required if I am not using the conduit as an equipment ground.
