Can low voltage damage a relay? I have a 120VAC relay, but the actual control voltage was 100VAC. The relay is a big HP rated ice-cube relay, which should handle 1/2HP and 16A, which is well within the size of the motor.
The casing that houses the contacts has a big black mark right next to the contact pads. Can this be cause by low voltage to the coil not opening the contact all the way or something along those lines?
