Is it Possible to take 6 poles to feed one circuit breaker for PanelBoard
leskfee19
Banned
Indiana
Hi all,
I do have a Distribution Panel With 8 branch circuit breakers (hree phase) whith rate 160 Ampere & 220/110 Volt so I would like to connect two circuit breakers from Distribution Panel to feed one panelboard with rate of 400 Ampere?
So is it possible to have two circuit breakers (6 pole) connect to one panel board?
thanks a lot
Not allowed. 240.8 limits circuit breakers from being connected in parallel other than listed factory assembled units.
Hi all,
thanks a lot
Yes, it is possible. You can also step into the path of a freight train.
Should you? Absolutely not.
Ref: NEC 240.8
thanks a lot for your help!
in fact that for a (project Site!
what about voltage that go thru 6 poles (output) to 3 phase input main C.K.
thx
