I actually agree that the sitck-on zip tie pads are about useless. The foam tape is cheap and will fall off in as little as a few days if there's any force on the wires. I consider the tape usable for positioning only long enough to get a screw installed. In the rare instance I've had to use them without a screw, I've peeled off the supplied foam tape (pretty easy, actually) and used 3M VHB tape in its place. THAT tape is wonderful - it'll stick wet ice cubes together. If only I could find the pads with the 3M tape pre-applied.
SceneryDriver
