Whenever I run into a nominal dimension in any industry there is always a table or formula published the will provide the actual dimension should the need arise. This is true of lumber, pipe, conduit, etc. But electrical cable has me perplexed. I can't find a cable manufacturer out there publishes the actual OD, or any clue how to deduce it. Rather they publish the nominal OD.
Lately I bought some ChainFlex brand 16/4 (a nice German mfgr) flex cable where the nominal ODwas quoted at 0.35. The actual OD measured 0.30. That's nearly 1/16" different, which can make a huge difference when using things like compression cord connectors, some types of strain reliefs, grommets, etc.
I have searched the entire NEC and Handbook and nowhere can I find how they come up with the nominal dim or some sort of rule of thumb.
Really I can't even say with certainty that the nominal OD will always be larger than actual OD. The with the ChainFlex I mentioned it is true, but what about SJOOW, or other types?
So could some cable sage out there enlighten me?
