RAFCOL
- Torrance, CA, USA
For example: for a wire AWG # 14, it is necessary to leave 2.00 square inches of free space, how they calculate this?
Thank you!
Thank you!
Why 2 in3 to wire #14, 2,25 in3 to wire #12 and no another value in3, and then, How did they figure those values 2 or 2.25 in3?
thank you
So that someone could give a better suggestion, first, we should know how the values given in Table 314.16 (B) are calculated,
for now, that's what my question intends.:happyno:
Only: How they calculated the values set in the table, that is.
In some cases. if the box is a junction box, this will have much more space, whether this is for a regular switch it's fine,
but when you incorporate dimmers or electronic devices, this is more complicated, especially when we have to connect neutral and ground wires.
Now, I do not know if the wire diameter is associated with these calculations, if so, they should be proportional,
and if the insulation is smaller than years ago, these values in the table 314.16(B) should also be smaller. It's just a hypothesis.
For now, my only question is: How were the calculated values set in Table 314.16 (B) ?,:?
Thank you!![]()
I kind of look this like why the staple needs to be within 12" of a box for NM cable and not 10" or 15".
It is less about the difficulty and more about the space. The thermoset conductors you mentioned to have slightly thicker insulation but is negligible in terms of overall space. Here is an example :I'd like to know why there are no adjustments for the diameter of the wire. It is a lot more difficult to fit #12 RHH/RHW-2/USE-2 in a box, than it is to bend #12 THWN-2.
In other words, it should be taken as absolute true? and there is no method to calculate these values as set?:?
From things I have run into apparently nobody ever read that section until about 1995:roll:This table has been in the NEC since at least 1940 code cycle (the oldest book I currently have). I'm not sure if there is anyone still alive who would know the methodology that they used to determine the amount of space needed for each conductor at least 75 years ago. :roll:
