Less line losses with the higher voltage, but those losses are going to be fairly negligible anyway.I have a motor that can be wired up for 460V 3 phase or 230V 3 phase. Is there any reason to select one voltage over the other? To me 460V gives the advantage of sizing the wires smaller, but I do not really see any other advantage.
That's the main advantage........ 460V gives the advantage of sizing the wires smaller, but I do not really see any other advantage.
That is the only reason to chose one or the other. If your facility has 480V, use that, there is zero reason to buy a transformer to make 230V. If your facility has 240V, installing and running power through a transformer to run the motor at 460V more than negates ANY possible savings on wire size or I^2R losses.I think the advantage comes from not having to install a step-down or step-up transformer if the motor is being installed in a facility that has one voltage but, not the other.
MANY years ago when we designed fiber handling systems, the price for the controls with 230 was higher than with 460 and 575 (575 ... textile south). Occasionally, the panels had to be larger as well. While the same motor was used, it was common to have to use larger starters and fuses.I have a motor that can be wired up for 460V 3 phase or 230V 3 phase. Is there any reason to select one voltage over the other? To me 460V gives the advantage of sizing the wires smaller, but I do not really see any other advantage.
That kind of goes along with the cost of larger conductors goes up as well.MANY years ago when we designed fiber handling systems, the price for the controls with 230 was higher than with 460 and 575 (575 ... textile south). Occasionally, the panels had to be larger as well. While the same motor was used, it was common to have to use larger starters and fuses.
