How can a 50 amp breaker protect 10 wire in a fault situation? Do you guys work on acs beyond running wires to them? Have you ever seen a faulted compressor that will run and draw extra amps without a direct short? What about extra resistance at terminals that will cook wire? Why didnt the thermal overloads protect in these situations? I dont think you quite undersrand the equipment, so your reading of the code is skewed and wrong. There is no reason to not match the wire size to the breaker. No benefit whatsoever.
