I have a question regarding 314.23 (B) (1)
macmikeman
I found myself involved in a discussion with a Jedi Knight about using the two holes in a 4'' square metal box to secure to a wood stud using screws. My understanding as it were is the referenced code prohibits this via last sentence of the paragraph. I understand the concept of passing thru regarding such boxes as gangible switch boxes, where nails were passed ''clear'' thru the box from outside to outside, but I think ''pass thru'' also includes screws passing from inside to outside as well. When a traveling person passes thru US Customs, it doesn't matter if they go thru two other countries first, or just start from one on our border, they are passing thru customs. I see the same language regarding passing thru boxes with nails or screws. Input?
I have used those holes and would again.
IMO that section prevents the screws from passing from one side to the other not simply through one side
I agree
I agree with iwire and so does the CMP as they have accepted my public input for the 2017 code to make it clear that you can pass screws through a single side of a box to support it.
I have used those 1/4" holes on the back and the smaller 2 holes on the sides to mount 1900 boxes to everything from wooden framing members to steel trusses for 20+ years. All inspected all passed i would imagine one inspector even the great Osceolo county inspector Roy would have mentioned something if it were not right. I've used wood screws, tapcons, bolts, sheet metal screws, etc... i think iWire had it right. The only hole you cant use to mount with on the back of that box is the 8/32 threaded hole that is for the green ground screw.
Sent from my SCH-I545 using Tapatalk
.... The only hole you cant use to mount with on the back of that box is the 8/32 threaded hole that is for the green ground screw.
Banish that thought right now.
You are not required to use that 10-32 threaded hole for box bonding only. The box can be bonded by any permitted means. The 10-32 threaded hole is just there as a convenience for when you want to use it for a bonding screw (such is not required to be green-colored either).
Why would the holes on the side of the box not be allowed when the holes in the back are allowed? It's the same difference...:)
For a 1900 box i dont see why you would want to use anything else. Are those cheesy ground clips cheaper yes, but cheaper is rarely better. And if i saw guys on my job grounding a 1900 box with something other than the standard green ground screw i would have a chat with that guy about professional standards when representing my boss and shop. And maybe mention having some pride in there work. And yea its a 10/32 not 8. had that size on my mind as i am running to a supply house for longer 8/32s lol
The section you've mentioned if for installations like this not using the side holes on one side with a fastener:
AxAebFZ-ZTPMjEwxU8S60rvhLordDqq7U5BAX2U5pbo=w636-h921-no
I agree with I-Wire also and Smart took the words right out of my mouth.
JAP>
Just pointing out requirement vs. myth, not debate the merits of one compliant means over another.
So let me get this straight, if you had a box of plain jane10/32's in the truck but no screws that had some resemblance of green on them, you would drive across town or wherever to get something that is sold as a ground screw even though there is nothing requiring it?
Heck, if a helper used a screw and nut because he didn't have a "ground screw" I'd compliment him / her for improvising to get the job done.
Finding an alternative way of doing something doesn't mean low standards? :roll:
Roger
I would wonder why the guy in charge of the jobsite or service truck ran out of stock of something as simple as ground screws... Whenever i get a case of boxes the first thing i do is have ground screws installed with dual pigtails then packed back up. So whenever a box or case of boxes is taken from the laydown area or out of the service van there is already a ground screw and double ended pigtail already in it.
