I've got a job where CIC wire was pulled up a high rise riser and we are now being called out for fitting and conduit type according to the UL listed specifications on the product data cut sheets. Set screw- out Compression- in...Anyways, there are basically 2 companies that make CIC cable these days as far as i know Radix and Comtran and only Radix makes 14awg and 16awg. Radix has a way better wire fill allowance and on the spec sheet allows for set screw fittings, we pulled the other brand
Anyone ever run into these issues? It's all about the 2 hour rating, for those who don't know. Any insight on why the restrictions on installation are so stringent? Seriously, you can't have more than a 12"x12" terminal or pull can and you have to use these ridiculous ceramic stand offs for terminations within the FATC....oh well. Love to hear from someone else who knows my struggle. Thanks.
