five.five-six
- california
I have a customer is having a piece of equipment installed that calls for a dedicated 220 volt 30 amp NEMA 14-30 receptacle. The cut sheet specifies if this ility has to avoid service appropriate techniques should be used to step up the line voltage. Is the buck boost transformer considered a separately derived power source and do I need a ground rod for it?
