emt/rmc transition
petersonra
Northern illinois
Semi-retired engineer
is there some code legal way to make this transition?
our local supply house says "everyone" uses an EMT connector threaded into a RMC coupling.
Just noticed the links I provided were specifically 1/2" but other sizes are available and in the biggest sizes a standard coupling is often listed for both.
1/2", 3/4" and 1" should all be easily obtained as it is common for electricians to come up out of a slab with rigid and immediately change over to EMT.
