T-Rope
- evanston, wyoming
So im on several locations installing and wiring these dog houses located where the pipeline protrudes from the earth and has an mov, up n downstream instruments, along with a pig sig. now the pipelines head electrician is having me bond the building at two corners. there is a fence about 25 ft sq which is also bonded to a ground ring 3ft away with 2 ground rods at opposite corners . the building corners are bonded to this as well as the the mov which is attached to the pipeline. listening to mikeholts grounding video on youtube, i am confused on levels of is this necessary, is it right , and or is it dangerous the way i am doing it . any input is appreciated
