any solutions for this besides a saws all and a paintbrush?View attachment 12926View attachment 12928The jumbo muttering from Leviton
doesn't have any extra depth is just wider
any solutions for this besides a saws all and a paintbrush?View attachment 12926View attachment 12928Cut out the drywall to the 4" X 4" box size and change to a 2 gang ring. A double duplex plate will still cover if you don't go crazy while cutting the sheetrock.
. The mud ring swap out I mentioned above is the easiest, if you don't mind having a quad recept box, instead of a duplex.
I never thought of the two gang jumbo
that's a winner thank you
?DawgI never thought of the two gang jumbo
In belief, man can do anything
Depending how it is fastened I have been able to band the box back further into the wall. Hammer and screwdriver
View attachment 12929any solutions for this besides a saws all and a paintbrush?View attachment 12926View attachment 12928
Now that we have that fixed what cha gonna do about the ground wire sticking through the receptacle strap? If that's what it is.
I don't think that's an acceptable termination.....![]()
Is that not the little welded wire that keeps the screw attached to the yoke in the package.
This replaces the old cardboard or plastic washer / screw keepers and makes the yoke "self-grounding" via the threads on the machine screw.
This replaces the old cardboard or plastic washer / screw keepers.
It's a self grounding receptacle. That little wire means you don't have to use a EGC on the device.That could be what I see.
Angle grinder. As long as there is still enough volume in the box after removing the protrusion, just cut the protruding part of the ring off with an angle grinder.
