mphillipps
300.20 (b) states that individual conductors pass through a single opening. When splicing K&T together with NM, I've always passed the K&T (hot & neutral) conductor and loom through two separate clamps with the NM passing through a third. Recently I've been asked to clamp the two K&T wires through a single opening. With a little bit or reading, I understand this is to prevent inductive current and heat.
My issue with 300.20(B) and K&T is that the hot and neutral are clamped closely together and if they were in separate holes there would be less chance of arching and the insulation of the loom would prevent inductive current.
My questions are: Does 300.20(B) apply to the splicing of K&T to NM? If yes, is there a preferred technique the splice K&T with NM? For example using a plastic box.
