Mountain Sparky
- Colorado USA
There is a ball field with sports lighting that was wired in the 70's. About 8 years ago new metal poles and lighting were installed. The existing 3 phase 480 volt service and underground wiring was left and reused. The pole lights are single phase 480 volt fed from a fused disconnect with 2 conductor direct bury wiring, there is no equipment ground. Each pole is bonded to a ground rod. If a conductor was to make contact with a pole would the fuse blow?
