No Ecuador has no NEC of any kind. People do whatever pleases them, sadly.
Well the biggest meter available is 125 amp.
I calculated off the bat that the amperage would be higher then 125 but i used american appliances a guide since its not easy to find that info here.
We must install inductions stove tops so thats 4O amps then an electric oven another 4O amps. a tankless water heater which i was calculating would be around 3O amps. Those are the biggest loads. Some other things like a washer and drier etc.
So that calculation barely provides anymore amperage for anything else. I know that if i bring in someone to do the conduit work they will want to do it one. I already had a guy come in and install 1 inch conduit for all these high load appliances and he said i was crazy and it was a waste of time to plan that far ahead. So i want to be sure of how i can make a proper installation so that in future i wont need to get new conduit.
The biggest problem is the concrete walls which need someone who knows how to work with concrete in order to break the walls makes 3 inch holes and then fill it with concrete again. So If i need 2 inch conduit, its best to do it now and not worry.
