Fused Disconnect - Rear Conduit Entry
xguard
Baton Rouge, LA
What requirments apply to entering a fused disconnect (600A) from the back of the disconnect? Specifically how close can the edge of the conduit entry be to the lugs. This installation is parallel 350MCM.
I agree there must be 8" to the enclosure wall opposite the lug entry, but there is no spacing requirement for conduit entry to lug that I know of.
I was wondering about that.
I will be honest, I punch holes where I want and make it work. Never been called out on it.
I usually don't place the edge of the KO any closer than what the edge of the lug is to the closest part of the enclosure.
Jap>
In reading all of 312.6, especially the 1st paragraph of 312.6 itself, and the header to the table "Minimum wire bending space....", I have always thought the Table applied to the deflection of the conductor itself. You have given me pause for 2nd thought.
I guess we could just let the conduit rub right up against the lug and be code compliant then ....:p
JAP>
Design parameters permitting, I'll put KO's as far away from the terminals as I can in a disconnect. Given restrictive parameters, I do as iwire does... make it work.
Lug would have to be pretty close to back wall to get it to rub. That's not going to happen if I have any say on the matter... :roll:
There's no bending radius requirement for individual conductors... only the space to bend them. I've had to do what I call curly Q's to get the wire in the lugs. Definitely not pretty, but if it works... :blink:
Curly Q, loop whatever you want to call it.
Sometimes you just can't get the pipe into the equipment in the best location for pretty conductors in the enclosure.
I was thinking the OP might be concerned about the conduit shorting out to the terminal from being too close, rather than the wire bending issue,,,,, maybe not.
JAP>
