enireh
- Canyon Lake,TX
does ac power feed in and then an inverter changes to dc power throughout the rv? I have a 1955 and we are wanting to go solar but it seems that's going to be a lot of problem
I am not all that familiar with what is typical inside RV's, but inverters change from DC to AC, a rectifier changes from AC to DC. An inverter should be exactly what you need to convert the DC output of your solar equipment to AC, otherwise if everything already runs on DC then your solar just charges the battery, but you may need conversion equipment if output is not same voltage as the battery.
Do you really have a 1955 RV or is that a typing error?
If you do have a 1955 was there power conversion equipment originally installed or was it added?
its was made in the area of 1955-60 the people we bought it from told us. It has a Square D panel with four 15 amp breakers when testing the outlets I read 120 volts so its ac power in the trailer
I'm new at this forum stuff so have patience
They were talking of a 6 or 7 wire for trailer road lighting .
