dmulhol925
Does a terminal box containing 24vdc, 4-20ma signal require 3' of working clearence?
Where special permission is granted, low voltage systems may have less working space than the NEC would otherwise allow. 60 Vdc or 30 Vac.
Special permission means that the inspector writes his/her name on it, and agrees with your judgement call, allowing you to do it. Not a good thing to rely upon, unless you know it in advance.
Can you cite the section allowing that?
