I'm trying to give my input on the design portion of a job where the existing service panel will be used as a sub panel fed by the new service that is going to be installed. I'm trying to convince the customer to replace that panel with a comparable load center, so we can get it ordered with the rest of the equipment, but the engineer has talked him into keeping it. As far as I know, a UL listed service panel cannot be used as a sub panel even if you remove the bonding jumper. I've been written a correction on this before. Any thoughts or input on this subject.......?
Sent from my SM-N910V using Tapatalk
