SHILGEFORT
Does NEC section 210.12 apply to sleeping rooms of a nursing home?
210.12(A) refers to Dwelling Units......a sleeping room in a nursing home would not be a dwelling unit.....Now knowing nothing about the actual "nursing home" layout and so on I will leave it at that.Does NEC section 210.12 apply to sleeping rooms of a nursing home?
No more or less than most GFCI receptacles have for many years.This AFCI picture may answer the Equipment Grounding Conductor up or down question ?
Don
Don
Don
How so ? The words "Test" & "Reset" are both imprinted to be read in either orientation. In a horizontal installation which direction would you suggest ? This topic has NO resolution.
Correct, not even good enough to put the ground up/ground down debate to restI was hoping that the AFCI was good for something but as they are they are good for nothing .
Don
