Existing Equipment, new application
kelli
Austin
Hi;
I am designing a new commercial space from an existing. They have told me I can use the existing Electrical Equipment which is to be abandoned by the previous tenant. They previously had all the Mechanical on a panel fed from an ATS. We don't necessarily want that. If I show a one-line with all the equipment essentially 'new' (because I am re-using, but renaming- and will note as such), what are the implications of not putting that ATS in the loop? I hope this doesn't seem too confusing, because I am a little confused myself. Thanks for any help!
Hi;
Are you leaving the ATS in place and just not using it, or removing the ATS and connecting the conductors?
I'm not sure yet if that would make a difference, just wanted clarity.
I am trying to decide, but am thinking that it will be left in place and not using it. I want to feed from the high volt panel that is in that stream. We are not showing any demolition at all. I will have to handle it with detailed notes?
