david
- Pennsylvania
He won't do it again.![]()
No more then it cost to rent a power washer for a few hours. After that kind of treatement I'd guess it won't look much different then it did before this happened, other then it may still need some paint. If whoever does it uses proper PPE for handling asbestos maybe a little more on labor.Wonder what its going to cost to repair the asbestos siding?
Wasn't by chance only metering 120 volts with a 120 volt only meter being used?240/120 volt service three main panels grouped in the basement. anyone notice how the meter was wired? Line one on the A terminal of the meter The neutral conductor landed on the B terminal of the meter and their is a jumper on the B side.
Since the whole service is being repaired it wasn't investigated further but i am amazed what people will do in the name of a repair.
I had the asbestos siding on my house removed contractor had to fill out all kinds of paperwork to dump them, after paperwork was done they had him dump them in the same spot as other debris.
That was for removal my comment was on repairing what was in the OP, probably just needs a little cleaning to get it back to about the condition it was in before this incident.I had the asbestos siding on my house removed contractor had to fill out all kinds of paperwork to dump them, after paperwork was done they had him dump them in the same spot as other debris.
