martinelectric2
- San Diego
I am working on a new home here in San Diego, CA. The house is built on a hill so the front entrance is at street level and the garage is detached from the house and accessed from an alley. The main services come from the alley, run through the garage and to the house. The garage and house are about 20' apart. The copper water line runs through the garage and then down to the house. The 200A service is on the corner of the garage and is grounded to a ufer and water pipe at the garage. A four wire run (2 hots, neutral and ground) are run to a sub-panel at the house. The sub-panel has the equipment ground bar and neutral separated. The inspector is asking for 2 ground rods and a water pipe ground at the sub-panel location. My question is, since the copper water line (buried in the ground from garage to house) is continuous, doesn't this qualify as a continuous conductive path and tie the two structures together as one?
