The primary side of this transformer is 12,470 and the secondary is a three phase 120/208 Y. The transformer feeds two 400 amp MDPs. The neutral is bonded at the transformer and at the 400 amp MDPs. Both of the 400 amp MDPs Have neutral loads so there is a Neutral at them. Does there need to be an equipment ground pulled to both MDPs from the transformer or would that create a parallel path?
