fisherelectric
- Northern Va
Existing residential installation circa 1960s
Fused Service disconnect (150 amp) adjacent to meter with 3 conductor cable feeding across the house to what used to be the service and is now a sub-panel w/ no main equipment grounding conductor and with circuit neutrals and equip grounds on same neutral bar.
Would it be compliant to simply run a #6 EGC along side the existing 3 conductor feeder from the disconnect to the sub-panel?
