dmulhol925
Is there any requiremnet that says metal enclosures need to spaced off of and block or concrete wall by a certain distance for moisture build up?
312.2Is there any requiremnet that says metal enclosures need to spaced off of and block or concrete wall by a certain distance for moisture build up?
312.2
My short spell in the food industry was with a Canadian company. Don’t ask me how, I went there as an engineer and somehow became production manager????
That isn't all that surprising, those kinds of position changes seem to happen a lot. The engineer (if they are good) are the only ones that know how things need to work, not just the mechanical items but the entire plant process from automated things to manual labor. Have a problem with a formula for a product or issues during processing - the engineer is the one with enough knowledge of how to deal with the problem, or at very least what can be done to salvage what you can instead of total waste of a batch or run of product.
You think they throw away bad product in the food industry - not unless absolutely necessary. Lots of stuff that is not hazardous but not up to specifications gets re-blended with new product has a way of being "reconditioned" or they find another use for it in some cases. If not safe for human consumption it may be sold as animal food product. That engineer turned production manager is useful for those kinds of decisions.
Most load centers, panel cabinets, meter bases, etc. have the little "bumps" on the back that will hold them off the wall. I haven't measured them but I would bet they are close to 1/4".
Do you run the strut vertically or horizontally? Thick strut or skinny?Very true. I usually mount on strut though.
