Custom wiring
Saw this today and had to snap a picture. Yes, that's a bungy cord holding the fixture in place
Wonderful. They just wanted to relocate the light fixture is all. I also like the added touch of the socket addaptor with the outlet with the addition of the plug addaptor such that they could plug is a plug with a ground plug. Now, he cool is that. That shows creativity. I',m surprised that they didn't add a 3 outlet cube addaptor to the other side which is a bit disappointing.
Oh, and that bungie cord is precious which provides a flexible mounting. But where is the duct tape for weatherproofing it?
One yellow and one red wire nut? Really?
You can clearly see the ground wire from the NM just hanging there.
The home owner is therefore required to put a "No Equipment Ground" label on that three wire receptacle adapter, even if he is using a GFCI breaker.
Maybe the wires are different sizes, justifying the use of different size wire nuts. :angel:
