Eddy Current
Is there a special type of lamp that has to be used inside a drink cooler door? T12HO? What about the ballast? The ballast is housed under the cooler, so its not in a cold temperature. Rapid start maybe?
T12 HO is what I am used to seeing.
Whatever kind was in there already.What about the ballast? Is rapid start what you would want? The ballast isn't in a cold temperature like the lamp.
A warm temperature ballast will not start a lamp in cold location.
Even though the ballasts are not normally in cold locations the case makers use low temp ballasts.
But the issue is the cold lamp more so then a warm or cold ballast (I think)
Though it is probably somewhat rare to see such an installation, I doubt a cold ballast has any problem starting a warm lamp.
Cold rated ballast is for cold starting. Standard rapid start ballasts are only rated for 50F starting while instant start T8 ballasts are rated anywhere from -20 to 32F. The use of HO is to make sure it stays warm enough in a refrigerated case.
But is it the lamp that has the cold starting issue, the ballast or both?
My suspicion is it is the lamp that is effected by cold, that is where we need to strike an arc. The ballast likely needs pretty extreme temperature conditions before it has any performance issues and it's impedance probably doesn't have much significant change in somewhat typical ambient temperatures - by that I mean any temperature that may be encountered where living beings also can exist, in the mouth of an active volcano - it may have some issues.![]()
