GBRZ
New User
- Long Beach, CA
I have installed a Creston lighting control system. Most of the LED bulbs work perform fine. I have however 3 zones of "Edison LED Light bulbs" that flicker occasionally. I have researched and discovered that this type of bulb is not approved by Creston. Lutron list it as approved, however, not on their lighting panel systems, only on a local dimmer and then only up to eight bulbs. At this point I have a lutron graphic eye with a lutron dimmer (double filter). This gets the only good results. The problem is that to control these three zones will cost about 3000 to 4000 dollars in Lutron equipment. Has anybody else had this problem and found a better resolution?
