- Wisconsin
- PE (Retired) - Power Systems
I have seen thousands of panels in my life, none of the properly maintained ones have 'burst into flames' except when someone was 'working in them'.
What caused the fault in the one you saw?
Your safety guys need to do a risk analysis, as required by NFPA70E. Your employees maybe more likely to be injured using a ladder to put and remove the arc flash blanket than they are by a spontaneous failure of the panel.
