This controller takes 2 30AMP circuits to run 8 basketball hoops. Each hoop wench is 11 amps. The conductors going to each hoop wench is #12THHN. From the controller the conductors come from a relay to the wench that has thermal overloads only. The only OCP is the 30amp breakers feeding the controller. Do I need to apply the tap rule and install overcurrent protection for the conductors at the wenches or at the controller?
