- Lockport, IL
- Retired Electrical Engineer
We are designing an apartment building with over 400 units. Each unit will have cooking and laundry equipment. There will be no electric space heating in the units, and no unit will have its own air conditioner or heat pump. There will be a central chilling plant and a Variable Refrigerant Flow (VRF) system for distributing hot or cold water to the dwelling units. In each unit, there will be a Fan Coil Unit (FCU). This is essentially a small fan that will blow air over pipes that have either cold or hot water that they receive from the VRF unit on the roof.
Question: Can the FCU be considered “electric . . . air conditioning,” in the context of 220.84(A)(3)? Specifically, am I allowed to use this optional load calculation method?
