JFletcher
- Williamsburg, VA
It's been a long while since I've been here... anyway, we (my area) is on the 2011 NEC... I only have the 2008 version. That aside, my question:
How do you properly ground a metal light fixture?
Scenario: metal (cast aluminum kind, 5 KOs) box, for lights, is fed by premise wiring (NM). Is it okay to ground premise wiring to ground screw provided in the box, then ground the light to the tie-bar ground screw, w/o the two being tied together? Are the screws/tie bar/box a sufficient ground path, or do the grounds of the light and the premise wiring need to be tied together, either by crimp or wire nut, to each other, after being wrapped around the ground screws?
