Hey all, I've been involved in a remodel of an older home. This home was taken down to the studs and new service was installed along with everything else, (insulation, drywall etc...). I was told by a journeyman/inspector that: I installed the water heater incorrectly by not installing a disconnect above it. It is protected by a correctly sized breaker, correct size wiring, etc... Am I to assume that it is required to have a disconnect installed? Where in the code book does that get spelled out?? Please give any and all feedback as this guy is holding up my final inspections until this is changed. If it's not required by code, then why do you think he is being so persistant for this change to happen?? The home is located in southern Indiana. Thx........
