Everyone,
In the gas industry plunger bars are used to detect and locate gas leaks. As you can imagine there is the potential for coming into contact with buried electrical lines. I'm trying to pull together a hazard assessment so I can determine the required PPE. I've reviewed 70E and it did not provide much guidance for this particular task. The plunger is rated for 10 kV. So a couple of questions:
1. What voltages are normally found in buried lines? You can assume the gas and electrical lines are in close proximity so induced voltage comes into play.
2. What PPE woul you recommend? How about arc rated clothing?
Thanks,
MikeCJ
Thanks,
MikeCJ
