JFletcher
- Williamsburg, VA
Long before any electrical training at all, I was told to use larger extension cords with long cords/runs, say for instance, drilling out studs, that significant voltage drop would quickly kill any motor under a decent/high load. What I'm not understanding is this: dont variable speed power tools vary voltage to the tool? and if low voltage kills a motor, then why does higher voltage? They are both drawing excessive amperage, yes? or does high voltage simply short it out b/c the tool isnt insulated for that? examples:
A 13A 120V drill on a 100' 12ga cord = no problem
A 13A 120V drill on 400' of 12/14 ga cord = overheats, will probably fail if used continuously/heavily
A 13A 120V drill plugged into 240V = poof???
If you plugged in a 100W 120V bulb to the same cords/voltages, you'd get normal operation, a little dimmer, bright then poof, yes???
Any links or comments to how motors work re: different voltages would be much appreciated.
